Build A Heavy Duty Engine Lift Plate:
Here is a small article on how to build an engine lift plate. You can buy them, but what fun is that? I have several engine plates, but they always seem to walk away or be lent out. I needed one pronto so I built this one. Save the debate on engine lift plates for another thread. I have used them for 25 years with great success.
I used a piece of 1/4" plate for the bottom plate:
I marked it and cut it with a 4 1/2" angle grinder:
I used a carb spacer and a transfer punch to mark the holes. The holes were drilled and de-burred top and bottom:
The vertical plate is a piece of 3/8" thick x 3" wide x 6 1/2" long. I built a small fixture for my lathe, and used an 1 3/8" holesaw on an arbor to bore the holes. You can also use a drill press or a torch to cut the holes:
The vertical plate is clamped in place, and welded:
A little paint, and it will be ready for battle:
ya, we lifted a few and refused to buy a lift plate for that money. So we made one as well. quite sturdy as well. will post pictures. It's a have-to-have
on that note: falcon do you have a website or something. Any place to accumulate all those how to make it yourself articles?
musnicki
09-23-2015 07:11 AM
