Lead Subsitute for Gas
Old 03-12-2011, 05:56 PM
wonso79
wonso79's Avatar
Question Lead Subsitute for Gas
Hi,
Would adding a Lead Subsitute to the gas hurt the engine if the car has been coverted to run unleaded fuel? I bought the car last year and the previous owner didn't drive it much the past 17 years so I am not sure if they converted it over or not.
wonso79 is offline
Old 03-12-2011, 06:34 PM
kalli
kalli's Avatar
No it won't hurt and in my opinion if you are not towing with your mustang you won't need it either. See what the others have to say. Just my opinion
kalli is offline
Old 03-12-2011, 06:50 PM
67mustang302
67mustang302's Avatar
Even cars set up for leaded fuel run on unleaded fine if you just put around. Performance is another issue, as it's mainly the heat and number of valve cycles that flog the valves/seats.
But no, you won't hurt it either way running a lead substitute. But the substitute is prolly something toxic that'll damage your nuts, so keep it off your skin.
67mustang302 is offline
Old 03-13-2011, 06:24 AM
wonso79
wonso79's Avatar
O.k. I'll give it a try and keep it off my skin and away from my nuts. Thanks!!
wonso79 is offline
Old 03-13-2011, 07:38 AM
hotrod351
hotrod351's Avatar
i had hardened seats put in my heads.
hotrod351 is offline
Old 03-13-2011, 08:04 AM
2+2GT
2+2GT's Avatar
Originally Posted by wonso79
Hi,
The only "conversion" would be installation of hardened valve seats in the head, which is common practice in rebuilds anyway. Valve seat recession when using the iron head as the seat turns out to be not the problem it was expected to be. Unless your car is a daily driver, you'll never see the 100,000+ miles it'll take to erode your seats. Come to think of it, Amoco stations sold unleaded gas in the 50's, 60's and 70's, and I never heard of any problems with their gas.
Look at it this way- At $2-3 a bottle, per tank of gas, how long would it take you to instead save up the money you needed to have hardened seats installed in your engine? Coupla years? It'll take longer than that to cause any damage. If you car is driven only to shows and cruise night, you'll never put enough mileage on it to require repair.
2+2GT is offline
Old 03-23-2011, 04:19 PM
.boB
.boB's Avatar
Lead was used in fuel mostly as a lubricant for the valves and seats. The only reason that unleaded fuel was invented is bacuase the lead kills the catalytic converter. Unless you have a cat, you can use lead in the engine without any problems.
The "conversion" for unleaded fuel was simply putting hardened valve seats in to resist wear, now that the lubrication is gone.
There are no street legal lead additives on the market. It is illegal to use lead on any public road anywhere in the US. And, the real truth is, you don't need it. Your engine will easily last 100K miles running unleaded fuel (with hardened valve seats). Don't waste your money.
.boB is offline
Old 03-23-2011, 04:31 PM
Oxnard Montalvo
Oxnard Montalvo's Avatar
I agree, save your money. Unleaded has been the norm since the early seventies and as stated the valve recession issue has proven to be overblown. I don't know anyone who has had a problem with it.
Oxnard Montalvo is offline
Old 03-23-2011, 08:51 PM
andrewmp6
andrewmp6's Avatar
I wouldn't use anything if it runs fine now then leave it alone.
andrewmp6 is offline
Old 03-24-2011, 01:46 PM
rwh129
rwh129's Avatar
How did you make out with the Lead Subsitute ?
rwh129 is offline
Quick Reply: Lead Subsitute for Gas
