Inline 6 2 barrel Carb upgrade Linkage?
I recently swapped out my original carb for a Motocraft 2100. I am having trouble designing a linkage solution for the carb. Has anyone done this with great success in the past? Willing to share ideas and pictures? Thanks for any help.
66 Mustang
200 ci
66 Mustang
200 ci
Neither, it is on the radiator side, facing you if you are standing in the front of the car. So it needs to move in a very strange way in relation to the original setup, basically perpendicular. The original setup had the linkage on the side of the exhaust manifold.
Edit: My thought is to use this long triangular piece that connects to something on the transmission. Link the throttle cable to that and then I need to mount the cable to the body, then again to the cylinder head cover, the issue is figuring out how to do it.
Bump:
This is what is shown on the Classic Inlines site
http://www.classicinlines.com/images...ogmod/M035.jpg
http://www.classicinlines.com/images...004%20009w.jpg
http://www.classicinlines.com/images...ogmod/LM33.jpg
Can anyone figure out how it was setup? I can see how it was mounted to the cylinder head cover but not to the gas pedal bar...
I've looked at the pedal but I cant quite see how it would work on my car as the pedal for a 66 200 is in the engine bay rather than the car interior. Do you have any photos of this setup? Thank you.
I am in the process of making a throttle cable set up for my 6ixer right now as soon as its done and I get my laptop back(couple days) I will get some pics up for ya. Its pretty simple just takes some stairing at for about an hour or so to figure it out. Oh and I am using the factory pedal and a Mr. Gasket universial throttle cable(30 bucks at Oreilly).
