T5 to 351w
Yes if you use the T-5 bellhousing..The trans will NOT bolt up to the stock 351 bellhousing without an adaptor..You will also need a 157 tooth 28 oz balanced flywheel..If you have the original flywheel off of the 351 it is probably a 164 tooth...The flywheel for whatever the T-5 was bolted to will be 50 oz balance so don't use it on the 351..You will also need to change the clutch fork setup inside the T-5 bellhousing unless you are going to run a cable to activate the clutch..This is not hard to do and you can reuse the stock mustang clutch linkage..
351, 351bellhousing, 351w, 68, forums, mount, mustang, support, t5, t5 trans, tranny, trans, transmission, windsor, windsor351
