Noisy Front end
Old 08-31-2011, 09:22 AM
HGC
HGC's Avatar
Originally Posted by kalli
can't believe it hasn't been mentioned yet :-) 99% of all mustang front end squaking is upper control arm bushings. grease em up.... I was suffereing that for 5 years (lube every 2 months ...) until I finally replaced them and I haven't heard of them sicne. You should have grease nipples that are impossible to get to at the upper control arm. grease there ...
Isn't that the reason you sometimes find Mustangs with holes cut in the shock towers?
HGC is offline
Old 08-31-2011, 12:47 PM
rtintwo
rtintwo's Avatar
Yup that is the reason the towers would have holes in them. I have never fully understood why they thought it was easier to cut the tower than it was to just unscrew the plug and screw in a 90* zerk.
rtintwo is offline
Old 08-31-2011, 01:35 PM
BeastMachine67
BeastMachine67's Avatar
Thanks for the feedback. I looked at the upper A arms and I noticed on on the nipples broke off. But, those big bolts that are on the outside of it, what is it there for?
BeastMachine67 is offline
Old 09-03-2011, 07:29 PM
jim1967
jim1967's Avatar
I had the same problem. I put in new upper control arms, then greased them, a year later the left was making noise. I tried to put grease in but it would not take any. pulled the it out, took off the grease fitting and then the big nut. the threads on the big nut were dry and rusting. i put grease on it, put in a new grease fitting and shot grease through the fitting before putting the big nut back on, problem solved. 6 months later I had to do the other side. 4 years now and no problem. good luck.
jim1967 is offline
Old 09-03-2011, 08:37 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the bolts are how you center the arm during assembly
rmodel65 is offline
Old 09-17-2011, 08:56 PM
BeastMachine67
So I finally figured out where that damn noise was coming from!!! it was the freaking sway bar!!!
Old 09-17-2011, 09:10 PM
1slow67
ROTM Moderator
1slow67's Avatar
told ya
1slow67 is offline
Old 09-24-2011, 12:33 PM
BeastMachine67
Originally Posted by BA Mustang
told ya
LOL yup!! you were right. I greased the crap out of the bushings and now I don't hear a single squeak
zsmart
Convertible Tech
02-29-2016 08:33 AM
the5
09-19-2015 06:13 PM
Sparks_88
09-08-2015 01:06 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Noisy Front end
