1965 Inline 6 conversion to late model 302
Old 09-09-2011, 10:22 AM
Foxstanger91
Foxstanger91's Avatar
Default 1965 Inline 6 conversion to late model 302
I have a 1965 Mustang that was my first car. I've had it for almost 13 years and I have almost completly restored it. It has a 200 6 cylinder in it and a 3 speed manual tranie in it and i'm thinking of converting it into a 302 that I pulled out of a 1991 grand marquis. I know i need to convert it into a 5 lug and put an electric fuel pump on it. I want to put power steering and disc brakes in the front.
What im really curious about is where the tranie be able to hold up to it if i get a 302 bell housing. My dad has a 66 that was completly restored and converted into a 289, but it has a automatic 3 speed in it. He didn't convert it hisself he bought it thinking it was a factory 289 already.
Foxstanger91 is offline
Old 09-09-2011, 11:09 AM
2+2GT
2+2GT's Avatar
You can put power steering and power disc brakes on the car now. As for performance, a T5 5-speed is bolt-on.
Changing to V8 is a massive job on a 64-66 6 cylinder car. You have to replace the cooling system, engine electrical, fuel system (electric is not required), exhaust system, entire steering system, engine, trans, driveshaft, rear axle, the entire brake system, and some small stuff.
The 6 cylinder C4 is not built as strong as the V8 version. The 2.77 3-speed you have now, if you can figure a way to attach to a V8 (I can't) will die in 3 seconds behind a V8 engine. The rear axle will die during the first burnout.
It's a lot easier to just go out and buy a V8 car if you really want a V8.
2+2GT is offline
Old 09-09-2011, 11:35 AM
scott_m_mil
scott_m_mil's Avatar
My brother just did the exact same thing with his falcon. A lot does have to change. Most of what 2+2 mentioned is correct, but I will make a few additions.
1) The three speed will be fine behind a 5.0. A toploader 3 speed is actually stronger than a T5, though not as fun. You CAN attach it to a 5.0 you need to get an old 302 bellhousing or a bellhousing from a 250 straight 6 out of the late 60's or 70s they use the standard small block bolt pattern and will take a toploader no problems.
2)Which rear end do you have? the 7 1/2 inch (bolt on rear plate) won't take it. An 8 inch will be fine no problems upto ~350 ft pounds of torque or maybe more. I would actually take one over a modern 8.8.
Scott
scott_m_mil is offline
Old 09-09-2011, 12:14 PM
2+2GT
2+2GT's Avatar
Unless his car has already been partially converted, he'll have the tiny 2.77 3-speed, and the 7" rear axle. The 2.77 is so small a child could carry it.
The 67-73 6 cylinder came with the 3.03 3-speed, same as the V8. That one will even stand up to the 390.
2+2GT is offline
Old 09-09-2011, 07:48 PM
MonsterBilly
MonsterBilly's Avatar
why not turbo your 6 and re gear it?
MonsterBilly is offline
Old 09-09-2011, 09:20 PM
2+2GT
2+2GT's Avatar
There are no performance gears for the 7" axle. The T5 5-speed makes a huge difference, though.
2+2GT is offline
Old 09-10-2011, 01:19 AM
MonsterBilly
explorer rear end for $450. its a great upgrade 3.73 gears
Old 09-10-2011, 02:07 AM
andrewmp6
andrewmp6's Avatar
I wouldn't mess with a 8.8 if you look hard you can catch a 8 inch cheap or even free.
andrewmp6 is offline
Old 09-11-2013, 05:05 PM
Justin Coffman
Justin Coffman's Avatar
I have a 1965 mustang and was wondering what year explorer I would get the rear end from, And would it bolt right up or do i need to make brackets of some sort?
Justin Coffman is offline
bradleyb
11-27-2015 07:50 PM
Urambo Tauro
10-05-2015 09:37 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Florida Regional Chapter
09-30-2015 08:04 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: 1965 Inline 6 conversion to late model 302
