What sort of MPG should I be getting?
Old 10-17-2011, 01:18 PM
wgc68nyc
wgc68nyc's Avatar
Default What sort of MPG should I be getting?
Here is my setup and I was wondering if I should expect more?
- original 302 iron top and bottom
- c4 trans
- aluminum intake manifold off an 80s Stang
- pertronix 2 with pertronix 2 coil (now with resistor wire bypassed) w/ hip wires
- new plugs, autolites left at .35 gap
- holley street avenger 570 carb (mechanic tuned along with timing)
- mild cam
- single exhaust with original exhaust manifold (slight leak)
- have an A/C system hooked up but not using now
I am getting about 13mpg with mild driving with occasional spirited moments.
Will I get an improvement if I gap my plugs to .40?
Should I try to tune my carb a little leaner?
I do smell gas now and then so I wonder if I am still running rich.
wgc68nyc is offline
Old 10-17-2011, 01:36 PM
MustangFTW
Guest
Posts: n/a
I say that's just about right.
Old 10-17-2011, 02:16 PM
1971mach1
1971mach1's Avatar
Timing and carb tune will affect your mileage the most.
The more advanced the timing the better the mileage. But if you go too far it will ping
on accelleration (bad for the engine). You'll get better MPGs and less pinging if you run premium gas.
But you'll have to advance the timing to compensate for premium.
13 around town is about right, but on the highway it should get closer to 18-20.
Have your mechanic look at why it's making the gas smell, it shouldn't do that. Maybe it
is running very rich or worse has a gas leak (which could result in a fire). Look for gas on the intake manifold around the carb first (most likely), then check the hose connections.
1971mach1 is offline
Old 10-17-2011, 04:29 PM
wgc68nyc
wgc68nyc's Avatar
Ive heard 18-20 is what I should get if I had a t-5 manual as opposed to a 3 speed auto with a 2.79 in the back. I had hoped to get to 16-18 and I already use premium but I had to add lead subsitute for my original valves. Probably should check my tires pressure and specs as well.
If everything is running great I am guessing it might not be worth it to try to squeak a few mpg out of it. But every time I look under the hood those Holley screws stare at me and beg to be fiddled with.
wgc68nyc is offline
Old 10-17-2011, 06:30 PM
2+2GT
2+2GT's Avatar
I got 14-18 with a 289 High Performance topped with a 3-2V intake. 13 is on the low side. My A code 289 4V got 15-21.
2+2GT is offline
Old 10-17-2011, 06:59 PM
MustangFTW
Guest
Posts: n/a
my stock 289 with 2 barrel carb got 13-14 before rebuilding, well see what it brings to the table now
Old 10-18-2011, 12:29 AM
andrewmp6
andrewmp6's Avatar
Jamesw go 20mpg with his fastback before but its a 5.0 and t5 in it is why.Mine i get around 8mpg with a aode but i have a nasty small block in it and i drive it fast.
andrewmp6 is offline
Old 10-18-2011, 06:18 AM
kalli
kalli's Avatar
i get just short of 20mpg on motorway at 60-70mph, but once I'm in town or floor it this reduces to nothing
kalli is offline
Old 10-18-2011, 07:52 AM
1slow67
ROTM Moderator
1slow67's Avatar
I average 13 mpg with mine. I have a somewhat high mileage 302(~95,000+), edelbrock 600cfm carb, weiand intake, T5, and 3.00 gears.
1slow67 is offline
Old 10-18-2011, 09:57 AM
frdnut
frdnut's Avatar
My stock J code got 21mpg(imperial gallons) on the highway with 3 speed manual and a 3:1 rear gear..
frdnut is offline
Quick Reply: What sort of MPG should I be getting?
