Everything was going great until..
So i just recently installed new KYB schocks on my 67, with addition to the lowered springs and 1 1/8 sway bar that I already had on the car. Nothing feels better than when you install new upgrades on your car then go take a test drive and feel the difference.
So anyways, I test drove the sh**T out of the car today, and it was all fun up until I was a block away from home, when I came a stop sign, I hear a loud "POP" sound. I pulled over, looked under the car, found nothing. Then as i slowly drove it home, the car kept pulling to the right. I jacked up the car and found nothing broken or loose or out of place. It does however, seem like I knocked the alignment out of place. If that's possible I think this is probably the second time I managed to do that.
What do you guys think it is?? has anyone else had this problem?
I wanna say it could be the inner and outter tie rods but, I keep all my bushings greased and every time I've taken it to an alighment shop they've always inspected the tie rods and I've been told their in good shape.
Sounds like your coil spring seated itself into the pocket. It may have shifted when you lowered the car off the jackstand, and then popped into place as the load shifted forward at the stop sign. That would change you toe slightly and cause a pull or push.
It's funny that you meantion that. When i bought the car, I had to find out the hard way that the car had perviously been hit on the passenger side. Of course the owner never told me that but, the lower valance was dented on the passenger side and when i first put on the 1" lowering springs on, only the passenger wheel would rub on the fender. If you look real carefully at the passenger fender compared to the driver's side you'll see a bit of a difference. as if it was bent, then pushed back in. Maybe someone did hit a curb with this car but, I just want to be able to enjoy driving it however I please without throwing my alignment off.
Before you drive the car again immediately check the lower control arm bushings for damage/ looseness. I had a 63 nova way back when (same front end style) and when the SRB wore out, the thing would almost swap lanes when braking.
