I posted this in the boost forum NO Reply
Old 12-03-2011, 08:57 PM
MonsterBilly
MonsterBilly's Avatar
Default I posted this in the boost forum NO Reply
I went to a local welding shop today and bought a 100lb tank full of nitrous. I am on mt way to lowes to get ann adapter fitting and hose to fill my bottle.
I will also get an electric blanket to put on the 100lb bottle and a scale to weigh the small bottle.
I did notice that the nitrous they sell is labeled as nitrous+ it has 100ppm of sulfur added. I know this is to eliminate the inhaling of the gas.
Will the sulfur cause any negative effects to my cylinders or to the intake parts.. I have done a lot of internet homework and this seems to be the most economical way to get the juice.
I paid $140 for the deposit on the tank. Then $145 for the nitrous. SO it breaks down to $1.45 a lb. the cheapest price i can find on nitrous locally when having my bottled filled is $7.99 a lb.
Anyone out there doing this, please let me know if i am going in the right direction and if there is anything that i should be concerned about other than the obvious with transfering the gas.
MonsterBilly is offline
Old 12-03-2011, 09:50 PM
oxfordbp
oxfordbp's Avatar
I believe the sulfur is added so you can smell leaks. I do believe burning sulfur leaves a residue.
Hopefully someone will be able to elaborate as I am only stating all I know on the subject which isnt much!
Good luck
oxfordbp is offline
Old 12-03-2011, 10:40 PM
djoneill
djoneill's Avatar
When I looked into this, my understanding was that I needed a compressor...
http://www.nitrousdirect.com/refillstation.html
djoneill is offline
Old 12-04-2011, 07:53 AM
MustangFTW
Guest
Posts: n/a
Any compressor should work, as long as it is able to pump the gas from the big tank to the smaller one.
Old 12-04-2011, 10:00 AM
JMD
JMD's Avatar
While the 100lb tank is near full you will get a good transfer without the need of pumping, as the big tank empties, you will get a proportional reduction in the amount of NOS that will transfer.
You will get a better transfer when the big bottle is warm, and possibly you will get a better transfer if the small bottle is cold....
I think the sulfur is added to ALL non-medical applications for the gas, including that sold for automotive use so it makes the sulfur a non issue.
IMO the sulfur wont hurt a thing, it may even help your valves a little.
JMD is offline
Old 12-04-2011, 05:27 PM
MonsterBilly
so far i have transferred one tank and it went fine. I am going to get an electric blanket to wrap around the 100lb bottle and I will stick the small one in the freezer. Man this way is a lot cheaper. Its only $1.45 a lb.
I do use a lot more though....
Old 12-04-2011, 05:30 PM
MustangFTW
Guest
Posts: n/a
it might stink when you purge the system lol.
Old 12-05-2011, 05:25 PM
03BottleFedGT
03BottleFedGT's Avatar
This is how we used to do it freeze the hell out of the small bottle and heat the big one
03BottleFedGT is offline
mtgldr
02-03-2024 09:00 PM
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
Galactic
04-29-2019 02:56 PM
carid
07-08-2016 09:55 AM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: I posted this in the boost forum NO Reply
