Last edit by: IB Advertising
Browse all: Exterior
- Ford Mustang V6 and GT 1994 to 2014 Why is Frame Squeaking
Guide to diagnose trouble and recommended solutions.
ARRRRGH! The squeak is driving me nuts
I have a squeak in the front end that is driving me nuts. It does not show up until I drive for a few minutes. but then the tiniest bump brings it out. It sounds like new rubber against new metal. I took it to the shop a couple weeks ago and told them to lube everything that can be lubed. Not sure what all they did but the squeak is still there. I can bounce the car before I leave and no squeak. When I get home and bounce it there is a non-stop squeak. I unhooked the shock (which is new) and the squeak was still there. There are new bolts/rubber bushings on the bolt that connects the sway bar to whatever that arm is called, which is new. New rubber bushings and new arm led me to believe that was where the squeak was from. I replaced the rubber bushings with poly ones based on the advise of a friend who thought that would make the squeak go away. It didn't. Now I'm not sure what else to try. Is it possible I tightened the bolt too much? Does it require some sort of grease between the bushings and the arm? The shop that installed it did not grease it. I don't remember having the squeak before I had the new ball joints installed. Any advice??
Thanks in advance.
Thanks in advance.
check your spring perches, and make sure the springs are seated in the pockets and the rubber is centered so the spring don't touch metal on metal anywhere. I also recall that poly bushings require a thin coat of lube between the bushing and the sway bar to prevent squeaking.
Could be your upper control arms. They squeak like crazy when the need lubed. If you have zerks on them at all they are hard to get to - that why you see some mustangs with holes punched into the shock tower. I shot some wd up in mine and squeak when away temporary but would come back pretty quickly - eventually replaced them. Put 90degree zerks on so I could get to it in the future.
You can check you sway bars same way - little wd 40. Some told me the trick when you put them on is wrap some teflon tape around bar where moutning tabs go.
I put a little wheel bearing grease on the sway bar bushings and the squeak was still there. So I ran it by the shop. The owner of the shop had me bounce it while he got under the car and feels pretty strong that it is the upper ball joints. I already had the lower ones replaced so it didn't surprise me when he said he thinks its the upper ball joints. I've used up my car fund money so I have to replenish it a little before I have the work done. Any chance a shot of WD40 will quiet it down a little? I suppose I should probably not drive it too much until it is done. right?
Thanks for the advice!
The upper control arm squeak is practically standard equipment in these cars. You need to get the special Mustang grease fittings installed if you don't already have them, and pump some grease in there. The squeak will almost certainly vanish immediately, even if the shafts are worn.
dalefrancis88
09-11-2015 07:15 AM
09-08-2015 11:50 AM
