Brake & Clutch pedal Repair
Own a 1966 Fastback,Took My Brake and clutch pedal assembly out and Fed-Ex't it to Mustang Steve for reduild and Roller Bearing install. any-body here done that ? Huge difference ? It was not one of my funnest jobs that i have done on car.
take the instrument cluster out all the way first,marking all wires as you go. I always draw little diagrams as i take each section apart which i know will pay off when i go to reassemble everything. but removing the entire cluster was the biggest help.
Sorry to say, but you probably just wasted some money. I believe if you were able to take the whole assembly out then you are some what capable and should be able to rebuild the assembly yourself.
I did mine. It took about an hour to do. I have the roller bearings and I will say that it is a slight improvement (a little smoother) then the old plastic guides in brand new condition. it's an obvious improvement over worn out plastic guides.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
