It just stopped?
It just stopped?
The other night I was out with my Mustang ('70 302) all original. as I was driving it just stopped firing, at least that's what I can tell. it still cranks, still has fuel pressure. all i came up with was there was no spark at coil..replaced coil. still nothing. all help would be much appriciated..
Thanks
Also I checked the forums couldn't find anything that was remotly similar since I already replaced the coil.
Thanks
Thanks
Thanks
Yep Guns right - let's start at the easiest place.
Spark or no spark.
no spark - turn the key to on and use a test light or DVM and check for voltage to the coil + side. it should be 9 Vdc or above ( or light is on)
do the same to the coil - terminal while cranking the car the light should pulse no pulse the points are not opening and closing or the condenser is shorted.
Spark or no spark.
o.k. here we go.
No Spark. replaced coil, replaced pick-up. no condenser, so that's not it. no points. Tested with test light and ohm meter, positive side of coil has power (9.3 Vdc)
Has an electronic Ignition.. Not the fuel pump, you can smell the gas when trying to start it.
It is not firing, why? that's the question that has me stumped.
Rotor, cap and wires are all new in July.
next step?
next step?
