Fuel injector hose vs regular hose
So I replaced my regular hose with fuel injector hose. I know that you should not run regular hoses on a fuel injected car because of the amount of pressure that that the hose needs to withstand. But what about vice versa since my car is carbed? I don't see an issue with this,but someone told me I should not do it. Does anyone have any insight on this matter? Thanks!
Are you sure it's FI hose, or simply CARB hose? The new CARB-approved Gates Barricade hoses are beefier, but not set up for fuel injection. They also come on a dark green roll, which is similar to the light green roll the fuel injection hoses come on. The company recently stopped carrying the older non-CARB-approved hose in most stores, but every store should still have plenty of low-pressure Barricade hose on hand.
Fuel injection hose is expensive. CARB-approved hose is more than non-CARB hose, but still much cheaper than FI hose.
I carry all of the hose options at my store. Most customers that need low-pressure fuel hose don't need (and don't want to pay for) the new Barricade hose. It's only "required" on 1986+ carbureted vehicles. It is a little hardier than the standard stuff, but the standard low-pressure hose still works fine in most situations, and is still ethanol-resistant. Ozone will eat the outside of the hose away before you have to worry about the inside drying up and cracking.
mrappe
09-26-2015 10:16 AM
