bad exhaust smell in the car
so if I drive with my windows down i get a lot of exhaust inside the car. i cant seem to dive it over 5 miles without smelling like a mechanic (no offense). I dont have any openings in the firewall. the exhaust does dump under the car though. is this my main problem.
it gets so bad sometimes i feel im going to pass out.
The exhaust pipe should exit behind the rear valance or outside of the rockers if a side exhaust; otherwise, the exhaust is channeled up through the trunk and into the interior. The fumes are minimized when all windows are closed and the front vent is opened.
Best,
Al
Best,
Al
its because the exhaust is dumped promise you.. i had same problem i had dumped flowmasters before axel and it smelled horrible had my side exhaust installed and problem was solved! either run it out the side or straight through to the back!
