Install a USA-66 radio???
Old 01-19-2013, 01:11 PM
Drail14me
Drail14me's Avatar
Default Install a USA-66 radio???
I'm working on installing a USA-66 radio in my '66 convertible. Trying to figure the best way to wire it.
The orange constant power wire I've read can be plugged into a 3 way plug in the dash near the cigarette lighter. I've found that plug.
However, I can't find a plug for the red "ignition" switchable wire for the radio. Anyone know where or if it plugs into the wiring harness?
Thanks,
Dennis
Drail14me is offline
Old 01-20-2013, 05:56 PM
noroof66
noroof66's Avatar
If you do not have have the original harness and wire at the radio, I would go to the fused side of the fuse panel. You can also tap onto the Ign wire for the radio at the ignition switch.
noroof66 is offline
Old 01-21-2013, 07:49 AM
Drail14me
Drail14me's Avatar
Thanks. I've still got the original wiring harness.
Old 01-21-2013, 10:10 AM
noroof66
noroof66's Avatar
If you have the factory harness/plug there you will have to splice onto it. I do not think there is an adapter for the radio to the factory harness. You must have unplugged the lighter to plug into the radio?
noroof66 is offline
Old 01-21-2013, 04:25 PM
jlg2002
jlg2002's Avatar
car radios usually have a switched and unswitched voltage requirement. one wire goes to the bat hot all the time (cigar lighter power wire is a good place for that power. The other wire goes to ign sourced power and that can be tricky. For the 66 that wire is the black-green stripe wired out of the center post of the ign switch. it feeds the fuses blocks. be sure to wire the correct sized fuses into both circuits. (the radio should have one on it. If either power wire isn't fused. i recommend you install it on the fused side of the power block. blue-red wire and black red wire.
jlg2002 is offline
mtgldr
02-03-2024 09:00 PM
Gkid182
09-22-2015 08:17 AM
unit91
09-15-2015 09:53 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Install a USA-66 radio???
