Over Heating
Old 01-27-2013, 09:12 AM
Pop's Stang
Pop's Stang's Avatar
Default Over Heating
Has any member here have a issue with your car over heating after using a new aftermarket fan blade? When I was working on my engine bay I switched to a Flex-a-Lite fan blade and now it seems I have over heating problems.
I plan on placing my stock fan blade back on, but just wanted to know if any other members had this problem?
Thanks.
Pop's Stang is offline
Old 01-27-2013, 02:37 PM
musnicki
musnicki's Avatar
How far is the fan from the radiator? Also, do you have a fan shroud?
musnicki is offline
Old 01-28-2013, 03:41 PM
Gun Jam
Moderator
Gun Jam's Avatar
yes I think other members have had issue just like yours with flex fans...the general populous (I think) believes flex fans are a bad idea..I know I do and not just for one reason.
They dont cool so great in some cases
they tend to be noisy
I have seen them explode at high rpm.
Gun Jam is offline
Old 01-31-2013, 09:56 PM
69dude
69dude's Avatar
Ive run flex fans on multiple Ford motors small and big with no problems (they had shrouds). Getting it closer to the radiator with a bigger spacer could fix the problem. Ive been told they could explode thus causing a lot of damage but if your not racing should be fine as most are rated to 10,000 RPMs. Try a larger diameter fan? Do you have a shroud, those make a big difference.
69dude is offline
Old 01-31-2013, 11:09 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
add a 3g alternator and an electric fan from a Lincoln Mark 8 and youll be all fixed up...but yeah id run the stock fan or a fan with a clutch(unless you wanna go electric)
rmodel65 is offline
Old 02-01-2013, 09:42 PM
Pop's Stang
Thanks everyone! I am planning on placing the stock fan back on. Will let you know!
PaulH2
20
01-31-2016 09:48 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Quick Reply: Over Heating
