Galaxie 289 Engine and C4 transmission
Old 02-06-2013, 08:53 PM
120mm
120mm's Avatar
Default Galaxie 289 Engine and C4 transmission into 1967 Mustang
Why wouldn't a 1965 Galaxie 289 with a C4-74 transmission fit in a 1967 Mustang?
Have an opportunity to get one at a reasonable price and am wondering if I should get it.
120mm is offline
Old 02-07-2013, 08:33 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the engine will fit...depending on if the c4 has a large or small bell housing will make a difference...mustangs use small bell housings with 157tooth flexplates
rmodel65 is offline
Old 02-07-2013, 10:47 AM
scott_m_mil
scott_m_mil's Avatar
If you are referring to the one listed on DSM craigslist - being a '64 engine it will be a 5 bolt bellhousing block and not a 6.
scott_m_mil is offline
Old 02-07-2013, 06:55 PM
120mm
120mm's Avatar
Yep, that's the one...
What is the relevance of 5 bolt versus 6 bolt bellhousing block?
changed: I'm a dumbcluck. I just saw that you answered the comment by the guy before you. Thanks!
120mm is offline
Old 02-08-2013, 10:20 AM
scott_m_mil
Actually I wasn't answering the guy before you. In about 65 or 66 they changed from a 5 bolt bellhousing to a 6 bolt (block and bellhousing changed). It was mostly to reduce vibrations and it increased the bellhousing strength as well.
Beyond being a 5 or 6 bolt there were larger and smaller bellhousing for different cars. Irrelevant of 5 bolt or 6 you will need the proper bellhousing. The 6 bolts can come off of 302's as well I believe and are relatively easy to come by. The 5 bolts weren't produced for too long and are harder to find.
To be honest, if it were me I would get a 6 bolt block. Additionally the one on craigslist is some what over priced in my opinion.
Old 02-08-2013, 11:34 AM
120mm
120mm's Avatar
This is good information. Thank you!
120mm is offline
4cylinderplus2
10-09-2020 07:45 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Galaxie 289 Engine and C4 transmission
