View Poll Results: A poll
chemical(and what type)
0%
Voters: 9. You may not vote on this poll
rust removal
rust removal
some of you have seen my pony and know there is a lot of rust. we all have it but what's the best bay to remove such massive amounts of it. when I wake up tomorrow, i'll begin stripping the car down and seeing what i can save.
RE: rust removal
Bead (media) blasting with walnut shells, etc., or sand blasting if you know what you are doing is the fastest way to get off the old paint. Once you can see the damage, then you can decide if the part needs to be replaced, or mended with a patch, or just needs to have a good coat of POR 15 applied. Block sanding is a very time and physically consuming way to get the paint off, and difficult to get into all the crevices. Chemical removal is a nasty way to do it, and not environmentally friendly.
RE: rust removal
ive tried everything so far except for sandblasting. they are all unpleasant. i am borrowing a friend's sandblaster once i finish some other work this week to do the underneath and other areas of the car. Soaring, you said, "or sand blasting if you know what you are doing", do you have any tips on how to do it. i dont need to screw anything up too badly.
thanks,
carl
thanks,
carl
RE: rust removal
Yeah Carl, if you hold the wand in one place too long with the sand, it will warp the metal. I would suggest if you choose this route, that you do some practicing on other metals before attempting sand blasting your car. Media blasting is not quite so harsh.
RE: rust removal
had my stang completely soda blasted and galvanized, then the body shop had its way with it. add a royal serving of dinitrol on the underside. hope it withstands belgian weather. still, really nice if you see it coming back after blasting, there is nothing left rust or paintwise, and not warped if done proffesionally like soaring pointed out...
RE: rust removal
wow harald, i bet the process that you took your car through cost more than my car in all.
Sandblasting is definitely the most efficent way to clear rust, but as with anything else in america, efficencey comes with a nice price tag.
Also, as Soaring mentioned, be careful with sandblasting it is very easy to mess up the metal, make sure to move the blaster around and not hold it in one place for to long.
The ideal way to sand would be to use a good ol' Sander, then using a sandblaster to reach any hard to get to areas, Jams, corners/crevices, underneath the car, etc. Good luck
RE: rust removal
ORIGINAL: 351foxstang
thanks,
carl
thanks,
carl
Here is some pictures of before and after:
Interior before
Sandblasted interior and there is some sand inside
Sandblasted engine bay
Sandblasted front
Front end painted so now it will not rust.
I have these pictures more so if you like to see I could show these every now and then when we have done something new.
RE: rust removal
thanks for all the info and pictures, i think ill end up doing the underneath, door jambs, insides of doors and some of the trunk with the blaster and use the electric sander for everything else.
carl
carl
jwog666
12-27-2021 08:09 PM
