good ol holley double pumper tunning
Old 04-29-2013, 10:32 PM
68dustin
68dustin's Avatar
Default good ol holley double pumper tunning
well hello folks, it's been a while since i've had to tune my other holley. So i just put a new motor in my 67 cougar with holley 600 double pumper. I think i kinda know where to start but opinions and suggestions always help.
Ok, this is what it's doing. At idle you can wrap up the carb to full throttle with no hesitation sputter or and problems at all. Now when you drive it from a dead stop you can take off and it's all smooth, until you get to where the secondaries come in. Then it breaks up bad and will clear up after a second. I'm thinking secondary adjustment/nozzle size... sound right?
this is my set-up:
roller 302
edelbrock aluminum heads
trick flow stage 1 cam
long tubes
edelbrock intake
stock dizzy with petronix
Carb: used but i just rebuilt it.
67 front jets with 6.5 power valve
73 rear jets no power valve
28 front nozzle
32 rear nozzle
fuel level: just barley trickles out when you push down on fenders
i think tomorrow i'm gonna start with playing in the secondaries.
***also i just took off a edelbrock 600 that was fine, so it's nothing to do with ignition**** thanks..
68dustin is offline
Old 05-01-2013, 01:46 PM
1970's Avatar
if it's a double pumper then the secandarys open with the primeareys and that may be two much gas for a 3200 pound car unless you are running a 4 speed with a lower 1st gear
1970 is offline
Old 05-01-2013, 01:54 PM
DocSnickers
DocSnickers's Avatar
I agree sounds like it could be flooding for a second, might want to try running it leaner on the primary. I ran a 650 double pumper on my 351 Cleveland and I had to run it leaner on the primary.
DocSnickers is offline
Nick Oliver
10-17-2018 04:22 AM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: good ol holley double pumper tunning
