What happened to my engine? *Video*
Old 06-23-2013, 02:39 AM
4reboy
4reboy's Avatar
Default What happened to my engine? *Video*
Hello everyone,
After a spirited drive tonight my engine made a sudden clicking noise and shut off. After pulling over and checking things out the sound seems to be coming straight out of the intake which makes me think the top end of my engine went out. Did I drop a valve?
Prior to this there has been a slight tick coming from my engine which I thought may have been a valve issue but was also thinking it could be my fuel pump. However, I'm still getting fuel so it's now clear that it wasn't my fuel pump. Is it possible I had an issue in my valve train and now I lost a valve?
Below is a video I took just after I broke down. Luckily I was right across the street from my final destination so I was able to limp it home after I boosted the idle up so it wouldn't shut off. Please let me know what you think the issue is so I can fix everything. Thanks!
Edit: Engine details: 3512w, edelbrock 650cfm, mild cam, stock heads, edelbrock performer intake, long tube headers, fmx tansmission
4reboy is offline
Old 06-23-2013, 05:14 AM
67mustang302
67mustang302's Avatar
Could be valve, or blown head gasket, hole in the piston....won't know till it comes apart.
67mustang302 is offline
Old 06-24-2013, 01:59 AM
sethalot
sethalot's Avatar
My vote is broken pushrod or rocker arm. Let us know when you find out.
sethalot is offline
Old 06-24-2013, 06:38 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
It sounds like air and I'm not hearing metal on metal. It sounded to me almost like a spark plug blew out. What does your vacuum gauge read?
First think I'd do is pop the valve covers, disconnect the coil and turn the engine over and see what's going 'round & 'round & up & down and what isn't.
fastbackford351 is offline
Old 06-24-2013, 11:18 AM
Iskwezm
Iskwezm's Avatar
yup...
Iskwezm is offline
Old 06-25-2013, 10:41 AM
Gun Jam
Moderator
Gun Jam's Avatar
sounds like a plug is missing to me as well...Im pretty sure its not a rocker, lifter or pushrod at least not primary. You might have failed rocker, bent pushrod and improper rocker lash secondary to valve failure.
If all the plugs are in place valve covers come off and check it out.
Gun Jam is offline
Old 06-25-2013, 11:50 AM
4reboy
4reboy's Avatar
Interesting thought about loosing a spark plug. I will definitely check them first before I pull the covers or anything else. That would be a much easier fix...
I had to go out of town on business so I won't be able to check anything until the weekend. I will keep you all posted, thanks for the feedback!
4reboy is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
zachary1988
09-04-2015 03:04 PM
09-03-2015 07:14 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: What happened to my engine? *Video*
