Best Carburetor 289 4 bbl ?
Old 06-30-2013, 01:15 PM
67mustang302
67mustang302's Avatar
Depends on the engine and use.
QFT with annular boosters or the newer Holley stuff (overpriced imo) with annulars is better then the older Autolite 4100 because of technological advances etc, but the 4100s are still great carbs that work well on mild engines.
What carb works best really depends on the engine. A mile street 289 that never goes past 5,500rpm needs a totally different carb than a 9,000rpm solid roller 427 drag engine.
67mustang302 is offline
Old 06-30-2013, 06:39 PM
Coupe
Coupe's Avatar
Originally Posted by mhubert89
my intake its a 289 performer by edelbrock that was already on the engine !
thanks for your times, i think i will go with the autolite 4100 !
Ok, but you will need to understand that carb does not seal on that intake. I had to use a thin steel spacer from summit under my pcv spacer and an extra gasket.
Other intakes with thicker sidewalls at the flange mount work better.
Coupe is offline
Old 07-03-2013, 11:19 PM
mhubert89
mhubert89's Avatar
So that will be better if i try to find a original 4 bbl intake or i can put a spacer from cj pony parts (Carburetor To Intake Manifold Spacer 1" 289/302/351W 4V 1965-1969) and that will work fine ?
mhubert89 is offline
Old 07-03-2013, 11:21 PM
mhubert89
mhubert89's Avatar
My engine its a 289 4bbl 4 speed and i will use it for a daily driver, no race or drag !!
Old 07-03-2013, 11:44 PM
Gun Jam
Moderator
Gun Jam's Avatar
I was told by qft tech that a downleg booster would be better suited for a medium-high performance 289 vs the annular booster.
This was the carb he recommended....I may try one out someday soon...they look fun
http://www.quickfueltechnology.com/c...arburetor.html
Gun Jam is offline
Old 07-05-2013, 10:01 AM
Coupe
Coupe's Avatar
I used this with my edelbrock intake & 4100.
Install a gasket, then this, then another gasket, then the stock style PCV spacer.
http://www.summitracing.com/parts/edl-2732
You can always use the Weiand stealth, it has a thicker sidewall at the mating surface and can fit more carbs.
Coupe is offline
Old 07-16-2013, 03:18 AM
tremman78
tremman78's Avatar
edlebrock with electric choke
tremman78 is offline
uberstang1
12-07-2017 07:10 AM
GTJIM
09-23-2015 09:59 AM
uberstang1
09-20-2015 06:42 PM
ryland
09-13-2015 12:35 PM
Brian Emmer
09-09-2015 02:50 PM
Quick Reply: Best Carburetor 289 4 bbl ?
