Neoprene or Rubber Bushings
#22
But lubing makes a rather large difference in suspension function. It works without lubing it, but it causes the bushing surfaces to not be able to move, so as the suspension articulates the bushings twist...almost like a tiny plastic torsion bar. The job of the spring is to be the spring, the job of the bushing is to locate the spring and provide some pliability to allow for spring twist during body roll and to absorb road harshness.
Lubing the bushings everywhere lets the surface slide inside the contact points, so the bushing doesn't twist. That way the spring does all the work and the suspension can articulate through the total geometric range. It makes for a noticeable difference over rough roads and under cornering on rough surfaces. Matched with a correctly tuned spring/shock combo, you'd be amazed what a leaf spring suspension can do when it's allowed to move.
Leaf spring suspensions have some inherent drawbacks in the way they function, they need all the help they can get. Most of the harshness and lack of control in leaf suspensions comes from all sorts of binding.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-16-2015 07:53 PM
