Idler arm won't seperate
Hello there
Someone please give me their trick to getting the idler arm to seperate from the center link becuase mine won't budge.
Thanks
Thanks
Ball joint puller.
http://www.sears.com/kd-tools-univer...1&blockType=G1
Just an example, but I've found that type to be one of the easier ones to use. Put it on, tighten it up a bit, then get it a few good whacks with a mallet, or some hard taps with a hammer and they tend to pop right out.
Don't even waste time with a pickle fork, they're useless, tear **** and and are more likely to get you hurt than get the job done.
Yep, pickle forks are stupid.
Back in the day workin' at the junkyard I ran across some tough ones.
I had a nice sized mallet that I would use as a back-up behind the eye and then whack it on the other side with another hammer.
Didn't really take a huge hammer to make it pop off when using a back-up.
This always worked for me.
...if it didn't, I got out the Victor Wrench.
Ive always used a pickle fork , while prying down with one hand use a ball peen hammer and peen the outside of the center link . This momentarily distorts the center of the beveled hole that the idler arm goes through. It always works for me.
You may have to hit it a few times and it helps to have an extra person .
The seperator worked thanks
Now how do I get the new idler arm end back into the center link. I feel like if I keep tightening the crown bolt (until it pops in) I might break something?
lincolnshibuya
12-08-2015 04:37 PM
