Can anyone identify this ignition type?
Old 08-30-2013, 09:29 AM
abrush
abrush's Avatar
Default Can anyone identify this ignition type?
I just purchased a roller 302 engine for a 65 Mustang fastback project I am working on. The motor was pulled from a running car. When I got the engine on my stand and popped off the distributor cap I saw that it appears to have a type of electronic ignition in it but I have never seen one like this before. I can't see any part numbers or brand name. I have used the Pertronix ignitor kits in the past but this appears to be something different. I didn't look how the distributor was wired before the previous owner pulled the motor so now I am scratching my head on what this is and how it is wired. There are 3 wires coming from it that are orange, purple and black. Obviously the black is most likely a ground but I am unsure of the routing of the others. The number on the side of the distributor is 12127 which dates back to 74-77 but obviously these units had points in them originally. Here are some pictures of the distributor:
abrush is offline
Old 08-30-2013, 11:50 AM
Sparkiewalt
Sparkiewalt's Avatar
the black is prob ground the orange is probablly 12V and the purple may be for a tach??
you can get a hei distributor off ebay with 8 mm plug wires to your door for just over $50. thats what I would do.
Sparkiewalt is offline
Old 08-30-2013, 12:53 PM
Iskwezm
Iskwezm's Avatar
thats a Ford Duraspark Distributor.Do a google search, theres a lot of information on them and they are pretty reliable and a cheap alternative to a name brand.
http://www.reincarnation-automotive....ons_index.html
http://classicinlines.com/DSIIswap.asp
Iskwezm is offline
Old 08-30-2013, 01:29 PM
abrush
abrush's Avatar
Wow, this helps a LOT!! I knew someone on the forum would have to know what this was and luckily I was right. I will do research on it so I know how to wire it correctly. Thanks a bunch!
abrush is offline
Old 09-03-2013, 02:45 PM
jlg2002
jlg2002's Avatar
You'll need the dura-spark computer also to make this work. I have had experience with the coil (blue object) experiencing an open which leads to a no- start or quits after running 1/2 hour complaint. FORD made millions of them and I agree they're a pretty solid unit. Also used in 4 and 6 cyls so make sure you have one with 8 poles on the reluctor
jlg2002 is offline
Old 09-09-2013, 09:42 AM
abrush
abrush's Avatar
Do I have to have the dura spark computer or can I run this with a MSD box?
abrush is offline
bradleyb
11-27-2015 07:50 PM
kevsgt
10-09-2015 10:12 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Can anyone identify this ignition type?
