stock or not?
stock or not?
bout to start buying parts and wanted to make sure....if im dropping a 302 into my 67' do any changes need to be made to the engine compartment area or can everything be stock?
thanks!
thanks!
RE: stock or not?
thanks guys! Soaring, the rust needs to be attended to....i made a post about the frame rails having to be replaced and im still a long ways from dropping the engine in, but wanted to know about the 302 fitting because i plan on buying all the parts at once(frame rails, floorboards, torque boxes etc.).
thanks!
thanks!
RE: stock or not?
Not a problem with slipping that 302 in your engine bay. The differences between the 289 and 302 are internal, so there will be no exterior differences in dimentions, etc. Get that darn rust out before you even consider what engine, etc. you need to go with.
mungodrums
Suspension
09-24-2015 10:12 PM
