Gas tank gauge issues
Old 04-09-2014, 01:27 PM
dragman72
dragman72's Avatar
Default Gas tank gauge issues
Ok, starting from the top.
As I am now driving my 69 while I am working on it I have ran into a problem. My gas gauge doesn't work, That isn't my biggest problem though. I haven't began to determine if it is the fuse, the wiring the float in the tank etc. The real problem I am having is that every time I fill the tank it kicks gas out all over the back and the bumper before it stops. and if that wasn't bad enough I filled it right before work and I park on a small hill and with the rear down it was leaking out the cap.
Are these normal problems??? or do I have a problem??
dragman72 is offline
Old 04-09-2014, 02:15 PM
67mustang302
67mustang302's Avatar
A lot of modern fuel nozzles at gas stations suck dick. They spill fuel while fueling up, and have a tendency to overfill the tank.
As for the gauge, you can replace the sending unit, and also try to make sure the tank is grounded to the chassis properly.
67mustang302 is offline
Old 04-09-2014, 10:10 PM
Iskwezm
Iskwezm's Avatar
with the key on, take the sender wire off at the tank and ground it.Your guage should peg full.If it does, that means the wire forward is good and its a sender issue. If it doesnt, could be a bad wire, guage or instrument voltage regulator
Iskwezm is offline
Old 04-10-2014, 06:19 AM
woodvette
woodvette's Avatar
i always had issues filling up too. i thought i had a blockage in the filler neck but did not find anything when i took it apart. i just had to fill up slowly. this was 20 years ago too. have not run the car in years tho.
woodvette is offline
Old 04-10-2014, 04:57 PM
dragman72
dragman72's Avatar
Good info will try it.
Gonna have to fill it gently
10-07-2015 07:02 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
zachary1988
09-04-2015 03:04 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Gas tank gauge issues
