Brake Warning Light on Dash
When I bought the parts to convert the front disks, it came with a power booster MC, which I can't really use with my low vacuum engine.
Is there a non-power MC option that would swap out easily, or am I headed towards bending new brake lines anyway?
That's the actual switch itself, but the parts the fail are inside the distribution block. There's a piston that contacts on the pin coming out of the switch. When the piston moves it triggers the switch to turn the brake light on. The switch itself is not what typically fails, it's usually the piston and related parts inside the distribution block.
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
It has been many moons but I believe what I used was a remanufactured master cylinder from a mid-70's F150 w/manual brakes and didn't do any brake line bending.
mungodrums
Suspension
09-07-2015 07:22 PM
