looking for a good awnser
i am looking at buying a 1969 mustang coup but it still has the original 302 and the 3 speed in it. what engine could i swap out and what kind of new better tranny could i put in and what would the price of a swap end up being. any info is appreciated.
thanks
thanks
The short answer is you can swap almost any motor in you want, just depends on how deep your pockets are. anything from a used 289 to a 429 big block crate to a brand new coyote DOCH 5.0 will fit (with the right mods). Cost really depends on goals.
add wide tires and a posi and traction bars and maybe it will burn rubber for 3 feet, lol.
As already stated, just about anything will retrofit into your car. The 289-302-5.0-351W family would be easiest and have more affordable options for a build-up. The T-5 is really easy to install and provides good driveability; however, if you are planning to do a lot of "burn-outs", especially from a dead stop, the 5 speed can be easily damaged. Clutch slipping burn outs should be done only with a toploader 4 speed and a well-built 9" rear axle. My personal power plant choice would be a 351W. Big blocks are an acquired taste that I never got.
Best,
Al
Best,
Al
You're going about this in the wrong direction. You're looking for power first and then budget. You need to determine budget first and then spend to get the most bang for the buck. Its a simple equation, more $$=more power/speed. If you have 10G to play with, do it all, if you have 4G to play with rebuild the stock engine but get better heads/intake/carb/cam. If you have 1G to play with get a cam and headers, port match your heads on your own.
Trivia note, the 3.03 3-speed you have is stronger than the T5 5-speed. The reason is the trans you have was almost identical, and even had parts in common with, the "toploader" Ford Design transmission.
mungodrums
10-07-2015 04:01 AM
