Which carb is the right one
Old 11-30-2014, 09:34 AM
kingstrider
kingstrider's Avatar
Originally Posted by sprog
What I'm asking is the carb on my car the correct one.The autolite 6-709.
Sorry, I overlooked the part number provided and thought you were talking about V8 carbs. If your Mustang has the straight 6 then it should have the Autolite 1100 carburetor which was used on both 170 and 200cid engines. There was no such thing as an Autolite 6-709, that must be the replacement number by whoever made or sold the carb. Regardless, a good overhaul should help with some of the problems you mentioned, providing you get the right kit.
Unfortunately the 1100 design is not very good and the layout of the intake manifold and cylinder head results in inadequate fuel distribution. When combined with varnish deposits, crappy fuel these cars were not designed for, problems with the vaccuum system or spark control valve (if equipped), performance issues such as hesitation and stumbling often result.
I would have a closer look at the harmonic balancer to make sure you are using the right timing mark. If you are off 180 degrees as described (7 o'clock vs 1 o'clock), you may not have the right mark. Sometimes you have to get up close with a flashlight to make sure you have it right. I typically highlight this with a white grease pencil so it shows up under the timing light.
Although this is frustrating, solving these kinds of mysteries is part of the charm in owning an old car. Keep us posted on your progress!
kingstrider is offline
Old 12-01-2014, 12:47 PM
sprog
sprog's Avatar
ok then....would it be correct to say that my 1966 mustang 200ci with automatic c4 transmission has the wrong carb on it as it does not have double pumps
sprog is offline
Old 12-01-2014, 01:08 PM
sprog
sprog's Avatar
Where might I find the correct carb?
sprog is offline
Old 12-01-2014, 03:35 PM
barnett468
barnett468's Avatar
most likely
barnett468 is offline
Old 12-01-2014, 03:37 PM
barnett468
barnett468's Avatar
most likely
http://www.championcarburetor.com/63...d-p-10401.html
Old 12-03-2014, 03:06 PM
sprog
sprog's Avatar
does anyone know where I can find a carb. for 1966 mustang with 200 ci motor and a c4 automatic.
sprog is offline
Old 12-03-2014, 07:18 PM
barnett468
barnett468's Avatar
yes, read post 15.
Old 12-04-2014, 06:59 PM
sprog
sprog's Avatar
Called them they don't have any.
sprog is offline
Old 12-04-2014, 11:31 PM
MonsterBilly
MonsterBilly's Avatar
try rockauto.com they do have some out of the ordinary parts. also, check local parts yards. you can usually get one used for $20 or so then buy an rebuild kit and follow directions.
ps, when rebuilding a carb, I find it helpful to soak it in chem dip for a couple days prior to rebuilding.
MonsterBilly is offline
Old 12-05-2014, 03:07 PM
barnett468
barnett468's Avatar
http://www.classicinlines.com/
http://www.oreillyauto.com/site/c/se...1966&make=Ford
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Sminemann
09-17-2015 09:24 AM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: Which carb is the right one
