66 brakes, upgraded
66 brakes, upgraded
I have the 13 in cobra breaks in m y 66 front and rear. I am running a 04 cobra manual master cyl.
the pedal is hard as hell. when I installed the system I used the factory distribution block for the front breaks and just capped off the rear port. the rears are connected directly to the MS with a prop. valve.
My main question is, should I be using that distribution block or not. I am thinking it may be limiting the fluid to the front breaks.
do not run the distribution block . . it has a frint brake delay valve in it.
if you see no change and your pedal engahement range is narrow like maybe 2" at the most, you can install a master with a smaller piston.
yes it is definitely the manual master for the 04. I think I found the part number from mustang Steve or one of the other websites though this forum.
so should I remove the distribution block and replace it with a tee
09-25-2015 06:42 PM
mungodrums
Suspension
09-24-2015 10:12 PM
mungodrums
Suspension
09-07-2015 07:22 PM
