Dealer installed dual exhaust?
I have an A code mustang fastback with dealer installed GT package.
What appears to be factory installed, Quick ration steering, front disc brake, 4-speed top-loarder trans and pony interior ( 5 bezel instrument group from factory.) Build date Feb 18, 1965.
The dual exhaust set up does not look factory, but notice the welded and threaded frame rail bolt/support for the exhaust.
Question: Would a a code car come without dual exhaust and what about the threaded bold inside the frame rail?
Thanks!
Frame rail support for exhaust dual bracket
Dual exhaust dual bracket off frame rail
Dual exhaust hanger, driver side
Under back seat
Thanks!
Under back seat
You can buy correct dual exhaust mounting brackets online so you can remove those incredibly long bolts. Not only is that setup rigged those bolt could stab a passenger in the backseat if you hit a large bump in the road.
nope, strangely enough, a dual exhaust non gt 65 - 66 car is virtually unheard of for some odd reason that seems to defy logic . . "lets build a more powerful engine and put sh_tty single exhaust on it" . . what an incredibly brilliant idea.
The T-code, C-code, A-codes (non-GT) were designed to run very quiet,which included the use of the single exhaust. Its one of the reasons why they used the large plastic timing gear sprocket!
I heard a stock 55k original mile C-code running once and you could barely tell it was running.
mryeah256
08-28-2015 02:01 PM
