Fuel Pump Gasket
Fuel Pump Gasket
The only leak on my car comes from the oil pressure sending unit, which I will be replacing with a fitting for a mechanical oil pressure gauge. To expedite this, I am going to remove my fuel pump to get better access to the oil extension thingy. I have already tried without removing, isn't happening. I see some kind of gasket on there now, can't tell if it's rtv or a rubber gasket. Summit only has a canton one that is called an insulator but it is really thick compared to what's on the car (I have it already). Do I just use fuel safe RTV? I can't find a paper or rubber gasket online. Thanks
351w
351w
mrappe
09-26-2015 10:16 AM
