351w Build Suggestions?
Old 04-27-2016, 03:47 PM
  #21
teeeeg67
teeeeg67's Avatar
This is the info on my cam. Trying to find the stuff for the rest of the stroker kit. The heads I used I think were part number 1458. But I'm not positive. They were 72cc 205 intake runners.
teeeeg67 is offline
Old 04-27-2016, 03:48 PM
  #22
teeeeg67
teeeeg67's Avatar
Let's try this picture thing again
teeeeg67 is offline
Old 04-27-2016, 03:56 PM
  #23
jwog666
jwog666's Avatar
thats a nice cam, my friend just called comp directly and told them what he was running for stroker kit, and heads, and comp custom ground him a cam. you could always do the same
jwog666 is offline
Old 04-27-2016, 04:23 PM
  #24
BKKSW
BKKSW's Avatar
Thanks. That's not as severe as I thought it would be. Should be really healthy like that.
BKKSW is offline
Old 04-27-2016, 05:41 PM
  #25
barnett468
barnett468's Avatar
Originally Posted by BKKSW
Let me ask you this.. does stroking a small block to such a degree cause issues with driveability, cooling, or reliability? We could get what... 430ci out of the thing.. so why have big blocks? I suppose i"m wondering why designers made the two different footprints.. and what we give up to stroke.
Have you used this company you linked?
Thank you.
As long as you don't go .030" over on the block and have a good cooling system, it will not run hot a 400 hp in the summer unless you live in phoenix az.
you dont want to go to 428 or 430 on a 351 windsor for a street car unless you use an after market block due to the poor rod ratio and short piston skirts . 418 is the biggest you want to go on a ford engine, and if you drive it daily and want it to last a very long time, then you should go slightly less.
barnett468 is offline
Old 04-27-2016, 06:02 PM
  #26
barnett468
barnett468's Avatar
the comp xe cams are decent but are a bit short on lift for stroker engines with good heads but you can compensate for that with 1.7 rockers . lunati voodoo cams were designed by the same guy that designed the comp cams and they have many good ones but the best cams for a windsor are probably the howards.
Here's how a howards solid roller with 269 276 . 236 242 .620 lift . 110 lsa sounds . i just finished helping my friend with this . the engine builder was a retard so i had to get a new cam and distributor and gear and solid core intake gaskets and special spark plugs and several other things to make it right.
this is starting it ice cold with no choke and 48 webers with the throttle 1/8 th down . it instantly idles which is extremely rare for an engine like this.
https://www.youtube.com/watch?v=X9E1...ature=youtu.be
Old 04-27-2016, 06:36 PM
  #27
barnett468
barnett468's Avatar
the cheapest way to get around 400 would be the following
dart or windsor 200 cc iron heads.
this cam
http://www.compcams.com/Company/CC/c...?csid=880&sb=0
eddy air gap intake or vic junior
750 carb
10.0 compression
true roller timing chain
eagle chinese h bean rods
chinese damper
stock distributor . add a pertronix I if you want
MSD coil . the anti vibration one is far better than the other.
at least 3.73 gears
Old 05-04-2016, 10:39 PM
  #28
BKKSW
BKKSW's Avatar
I tore down the 351w today. I couldn't have asked for better results. Its' the standard bore and journal sizes and everything looks great, no signs of anything bad happening.
The ridges are only 002-.005 and the taper is less than .003 top to bottom. I think I could cut the ridges, hone the bores, and go with that.. except I want to stroke it.
BKKSW is offline
Old 05-05-2016, 09:35 AM
  #29
barnett468
barnett468's Avatar
way too loose plus it is also out of round . it would smoke like the marlboro man . it definitely needs to be bored.
Old 05-05-2016, 10:52 AM
  #30
jwog666
jwog666's Avatar
^^^^+1
jwog666 is offline
Quick Reply: 351w Build Suggestions?
