FOUND: Mustang Clutch Pedal Assembly
Old 01-30-2006, 03:03 PM
superdavid
superdavid's Avatar
Default RE: FOUND: Mustang Clutch Pedal Assembly
I'm trying to track down a digital camera and I will definitely keep a detailed log and post it somewhere. I know how much grief I've gone through to find all the parts and info I need, and I want to save other people the trouble.
superdavid is offline
Old 01-30-2006, 03:09 PM
bryanvw61
bryanvw61's Avatar
so let me get this straight... there is no need to buy the whole assembly, just the pedal, spring, and bracket... and the rest of the linkage that you'll need is the same you'd need if you did buy the whole assemly right??
bryanvw61 is offline
Old 01-30-2006, 03:14 PM
superdavid
superdavid's Avatar
You will need to buy most of the parts to convert your existing assembly. I'll take a picture within the next few days of both assemblies sitting next to each other so they can be compared.
Old 01-30-2006, 03:31 PM
67t5ponycoupe
67t5ponycoupe's Avatar
The brace piece that goes between the dash and fire wall is the same. The brake pedal is only different because the bottom is bigger, so you really need the smaller pedal.
67t5ponycoupe is offline
Old 01-30-2006, 03:55 PM
67t5ponycoupe
If you had one to compare to you might be able to trim down the automatic pedal to take the pad for the standard pedal.
Old 01-30-2006, 04:01 PM
superdavid
superdavid's Avatar
Like I said, hopefully I can get some pics up by tomorrow and we can figure this thing out for sure.
Old 01-30-2006, 06:13 PM
Shifty101Easy
Shifty101Easy's Avatar
couldnt you just buy a manual set of pedals pad and just bolt those on the pedal shaft things?
Shifty101Easy is offline
Old 01-30-2006, 06:30 PM
67t5ponycoupe
No shifty, the pad is only a cover for the big piece of flat steel afixed to the end of "Pedal Shaft Things"
Old 01-30-2006, 07:05 PM
Shifty101Easy
ahh i see......well then unless u could bend the "pedal shaft thing" err.. "pedal arm" or whatever its called.....like kink the clutch one to the left a bit so it would clear the brake one.....otherwise i guess u would need to cut it....which probably wouldnt be all that hard either....
Old 01-30-2006, 08:15 PM
Shifty101Easy
ok so here is a rough list of what you would need for a T5 conversion....
I found a brake pedal for manual trans on that website....so i guess the automatic brake pedal problem is solved...
Its not complete...but its a start....anyone else got anything to add?
T-5 TRANSMISSON - $1,395.95
http://www.mustangsplus.com/Merchant..._Code=t5_trans
T-5 CONVERSION KIT 1965-66 $659.95
http://www.mustangsplus.com/Merchant...y_Code=t5_kits
-OR-
1967-70 T-5 CONVERSION KIT - EARLY BELL HOUSING
1967-68 CABLE CLUTCH KIT
http://www.mustangsplus.com/Merchant...5_cable_clutch
CLUTCH PEDAL RETURN SPRING $10.95
http://www.mustangsplus.com/Merchant...uct_Code=00882
BELL HOUSING - $??? (depending on tranny u got i think)
CLUTCH PEDAL - $123.45
http://www.trophymustang.com/196566-...al-p-2653.html
CLUTCH PEDAL BRACKET $28.95
http://www.trophymustang.com/196566-...pp-p-2287.html
MANUAL TRANS. BRAKE PEDAL $74.47
http://www.trophymustang.com/196873-...ns-p-4645.html
anything else?
Quick Reply: FOUND: Mustang Clutch Pedal Assembly
