Go Back   MustangForums.com > Ford Mustang Tech > General Tech > Convertible Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-28-2009, 11:51 PM   #1
ym42
ym42's Avatar
Default Leak or drainage problem in a 2006 vert
Its been raining hard in NJ and I have a new water problem. When driving, I can hear the water sloshing around the back seat. It seems like the sound is coming from the space where the rear triangular window and the belt go into. When I took the plastic cover off I could not see the water inside, despite using the flashlight inside. I looked below the rear window, the shelf is dry, so where is all that water? Is that a leak or a plugged drain? I have had water inside the trunk every time it rains as well, in both spaces on either side, left and right, under the carpet... Does anyone knows whats going on?
__________________
'06 Mustang GT Convertible
5 Speed Manual
Front Strut Brace
50k miles
ym42 is offline   Reply With Quote
Old 11-01-2009, 08:24 PM   #2
ym42
ym42's Avatar
OK, here is an update... When I lowered the top, I could see the water inside the rear quarter panel space, in the space right in front of the wheel-well. Its right under the rear quarter panel glass, deep down. There is a drain in there that was plugged. I just took a long plastic stick from the window blind, and was able to reach the bottom of the space and moved it around, immediately the water started to drain... When I have more time, I will remove the inner trim panel to reach the space by hands in order to remove the debris...
__________________
5 Speed Manual
Front Strut Brace
50k miles
2006, convertible, drain, forum, leak, leaking, leaks, mustang, trunk, water
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
