Sponsored by:
Sponsored by:
what tools are required to replace mustang 05 convertible top frame side rails
Old 04-25-2011, 11:36 AM
peng0318
peng0318's Avatar
Default what tools are required to replace mustang 05 convertible top frame side rails
i just need to replace both side rails and re-stratd the motor
peng0318 is offline
Old 04-26-2011, 07:15 PM
scan1959
scan1959's Avatar
Is this car wrecked? Up on the top, replacing the side rails means replacing everything except the center parts. This would require taking off the top and headliner.
Tools involved would be - Torx screwdrivers, stapler, torx sockets, socket ratchet, metric socket set, flat and phillips screwdrivers, allen wrenches or sockets and rivet tool (also rivets). You would also want to have a crowbar and large hammer.
It's a pretty big job!
scan1959 is offline
Old 04-27-2011, 10:35 AM
peng0318
peng0318's Avatar
Is it possible to change the rail assy at both sides without removing the whole top. Since i think my motor is not working, it cannot raising it. It worked before even when the rails were broken.
peng0318 is offline
Old 04-27-2011, 07:31 PM
scan1959
scan1959's Avatar
I'm suspicious you do not need to replace a side rail. Your description makes me think that your problem is related to the hydraulic cylinder that raises the top.
Peng,you need to take your car to an auto upholstery/trim shop. These are listed in the old Yellow Pages directories under "Automotive Seat Covers and Upholstery". These guys usually can diagnose problems without costing you an arm and a leg.
When someone comes into my shop and doesn't know what their car's problem is, I will charge them a reasonably small amount to look into it. If it takes a long time to get the problem diagnosed, the fee will be a little more. You are still better off paying the fee because now you can leave knowing what the job will cost.
Just wondering ("Is it going to cost $85 to fix my car or $650?") does nobody any good.
Does your motor make a noise when you push the top button? If not, you might have a bad switch, not motor problems. Can't tell here from my keyboard.
scan1959 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
vbonina
07-22-2018 08:12 AM
importsmasher
10-09-2015 04:42 PM
daytooday
08-11-2015 09:22 AM
Mustang Sally72
08-11-2015 07:54 AM
Quick Reply: what tools are required to replace mustang 05 convertible top frame side rails
