Sponsored by:
Sponsored by:
air sound and water leaking between top and windshield
Old 11-11-2014, 03:54 PM
jruppert
jruppert's Avatar
Default air sound and water leaking between top and windshield
Its an 87 Mustang with a new top. I have only owned the car for a couple months. When I get above 50 or so, I get air whistling through. Today on my way home from work, I noticed that I was getting water dripping through under seal. It was just drizzling out.
If I push up on windshield frame, I get a lot of air coming through. If I pull down, I can almost eliminate the air.
So.. how do I know when its the seal or if it needs adjusting?
jruppert is offline
Old 11-12-2014, 08:57 PM
Special20
Special20's Avatar
I would go with the least expensive first and try to adjust the top clamps. I am not sure on the 87 models but my 2003 adjusts with the hooks on the clamps that hold the top to the header. Good luck.
Special20 is offline
Old 11-22-2014, 06:38 PM
scan1959
scan1959's Avatar
Yes, tighten the clamps (J-hooks) by loosening the hex key bolt on the front of the hook, then tighten by turning counter clockwise.
Also, this model is known for needing a new weatherseal at the front header more often than later years. To replace the top, an installer has to remove it. Many times, it will tear rather than cleanly allow itself to be removed. When this happens, it might be a good place for water to leak through.
scan1959 is offline
Old 11-22-2014, 10:08 PM
cruisin5268d
cruisin5268d's Avatar
Well, there hasn't been any follow up so I am guessing his situation has improved.
cruisin5268d is offline
Old 03-01-2015, 05:14 PM
jruppert
jruppert's Avatar
I completely forgot about this post and of course it didnt send me an email once there was a reply. I need to buy an allen wrench to adjust these hooks. Does anyone know what size these things take?
jruppert is offline
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
1987gt40ttopt
08-28-2015 10:49 PM
Calizic
08-28-2015 01:46 PM
Hogquad
08-23-2015 05:26 AM
kirk35
08-17-2015 08:42 PM
Quick Reply: air sound and water leaking between top and windshield
