Sponsored by:
Sponsored by:
Problem With Connecting window to Top on Sides
Old 04-26-2015, 03:27 PM
DaveyJones59
DaveyJones59's Avatar
Question Problem With Connecting window to Top on Sides
I am running into a problem where, when installing my new convertible top, off either side of the rear window the two sets of fabric are not connected and you can put your hand through into the car so water would obviously leak into it. How should I close that gap, epoxy or glue maybe?
DaveyJones59 is offline
Old 04-26-2015, 04:46 PM
DaveyJones59
bump---------
Old 04-26-2015, 05:40 PM
cruisin5268d
cruisin5268d's Avatar
Did you seriously just "bump" after only an hour? lol wow.
Bumping is pointless, especially on this forum. Try having some patience.
cruisin5268d is offline
Old 04-26-2015, 07:25 PM
Special20
Special20's Avatar
I have not installed a top on my car yet but I can tell you that it is a 2 piece top and there is no need to glue the 2 together. I believe you have to redo the top and pull it tighter. It takes professionals a bunch of times to get all the gaps and wrinkles out. Good luck.
Special20 is offline
Old 04-26-2015, 08:53 PM
DaveyJones59
I know it is a 2 piece top but on those open flaps you can stick your hand in it and reach the inside of the car so water would easily get in there.
I also have to repull it and cut the excess vinyl off but I didn't want to do that until I figured out how to put it all back on.
Old 04-27-2015, 06:25 AM
Special20
Special20's Avatar
There is a dvd on ebay from aoksales.com that gives you detailed step by step instructions on how to remove and replace your top. there are lines on your new top that have to be lined up with the tack strip that is used as a starting point. i bought the dvd and it explains everything. good luck.
Old 05-06-2015, 09:38 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
+1 on the DVD. It is step by step and other than a broken nose, everything went perfect. Nice tight top with no gaps or leaks.
fastbackford351 is offline
Old 05-30-2015, 08:16 PM
scan1959
scan1959's Avatar
After you finish installing the top, if the sides are still loose, then you need to tighten the sides and back of the top by removing the tack rail, unstaple the top, pull it tighter and restaple.
Assume that you will have to do this several times before you are pleased with the appearance of the top.
Good Luck!
scan1959 is offline
Old 06-12-2015, 09:57 PM
302Ragtop
302Ragtop's Avatar
Wow man you need to pull that off and start over it looks like it is way too loose! One way I kept mine tight was to prop the top up a little so that when we were done and lowered the top it was tight. It was too tight but after letting it sit a day in the sun it stretched out and looked great.
302Ragtop is offline
Old 06-12-2015, 09:58 PM
302Ragtop
302Ragtop's Avatar
Also watch YouTube videos to get the general idea. It helped a lot.
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
spectreman
03-31-2016 09:26 PM
duffman668
08-26-2015 04:46 PM
Mustang Sally72
08-11-2015 07:54 AM
Quick Reply: Problem With Connecting window to Top on Sides
