Building a 331 stroker
Old 05-26-2016, 08:08 PM
427TBolt
427TBolt's Avatar
Default Building a 331 stroker
I have a 1991 LX convertible that has a great running stock engine. Recently I acquired a Scat stroker kit. I all ready have a new factory block so I would like you folks to tell me what cam and intake changes would work well with the EFI and aluminum heads. Any ideas would be appreciated.
Thanks Mike
427TBolt is offline
Old 05-26-2016, 10:34 PM
jwog666
jwog666's Avatar
not even close to the right section, you need to post this the the correct area if you want answers
jwog666 is offline
Old 05-30-2016, 01:15 PM
427TBolt
427TBolt's Avatar
jwog666, thank you for your informative instructions,except where in the H_ll is the correct area if it is not in "new post". Please educate me if you would be so kind.
Thanks Again Mike
427TBolt is offline
Old 05-30-2016, 01:38 PM
AK_Kayaker
AK_Kayaker's Avatar
What he meant was, it should be in the tech section, specifically the 5.0L (1979-1995),
so more people with like models could give the best help.
https://mustangforums.com/forum/5-0l...95-mustang-14/
AK_Kayaker is offline
Old 05-31-2016, 10:17 AM
427TBolt
427TBolt's Avatar
Thanks AK for the real info. I notice there is no such prompt at the header on this page, that might help us some.
Mike
427TBolt is offline
Old 06-01-2016, 07:53 AM
99GTvert
is my username.
99GTvert's Avatar
Moving to tech from FIF..
99GTvert is offline
Old 06-01-2016, 11:49 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
tfs 11r heads
holley systemax ported or box r intake
www.flowtechinduction.com =cam, he'll spec it for the combo
all supporting mods ect ect.......build the 331 right and with all supporting mods, you'll need at least 10k.....or go on the cheap and use 302 parts on the 331 and get schooled by well built 302 combos
mjr46 is offline
Old 06-07-2016, 04:30 PM
427TBolt
427TBolt's Avatar
build the 331 right and with all supporting mods, you'll need at least 10k.....or go on the cheap and use 302 parts on the 331 and get schooled by well built 302 combos[/QUOTE]
10K sounds a lot too expensive to m! Maybe my 351w would be cheaper to install in my car!
427TBolt is offline
Old 06-08-2016, 07:40 AM
88 orangepeel notch
88 orangepeel notch's Avatar
What are your intentions with this car ? Street , Strip , Show or groceries ?
88 orangepeel notch is offline
Old 06-08-2016, 01:17 PM
mjr46
mjr46's Avatar
351 Windsor will still be slower than a well built 331/347
mjr46 is offline
Quick Reply: Building a 331 stroker
