Sponsored by:
Sponsored by: DashLynx
Clutch ?
Old 09-24-2007, 04:49 PM
kmoore57
kmoore57's Avatar
Default Clutch ?
Can you adjust the clutch on a 96 Mustang GT 4.6?
kmoore57 is offline
Old 09-24-2007, 08:08 PM
johnnyhou
johnnyhou's Avatar
Default RE: Clutch ?
I am guessing not since most of the newer cars have a master and slave cylinder (hydraulic) and the slave cylinder is behind the throwout bearing so the transmission has to be removed to replace and special tools are needed to disconnect the hydraulic line. Put some brake fluid in your clutch master and pump the clutch for a while and you should be okay.
johnnyhou is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Clutch ?
