Want to improve cooling system but have questions...
Ok, I have an 97 GT vert with an auto. Is stock a 2 or 3 core and is there a Ford performance radiator that I can get with 1 more core?? Also, who sells a really good fan that will bolt right in with no or minimal modification? Is the stock water-pump our only option, or is there a high flow made for our cars??
RE: Want to improve cooling system but have questions...
i don't know how many cores the stock radiator has, but there are lots of options out there for aftermarket radiators. check summit.
your stock fan should be fine... are you having overheating problems? the best fans are the ford factory fans. ex: i run a fan from a taurus along with a dcc controller.
stewart makes high flow waterpumps, but some people have issues with them.
It is not overheating, but just runs hotter than I typically like my cars to run. I like them to stay pretty consistant, even when tromping on them. My truck is extrememly consistant but the Mustang isn't there yet. I am sure a programmer may help if I change the fans operating temp. I did a flush on it and have a 180* thermostat in it. It is the original water pump, so I am not sure if it still has its peak effectiveness? I will probably look into upgrading the radiator and putting a new OEM water pump on it also. What are the best to use....Fluidyne??
what percentage coolant/water are you running? water dissipates heat better than coolant so run like 70% water and 30% coolant.
fluidine are good rads but there is cheaper stuff out there. i know that for fox bodies the summit universal rad fits with minor modification but i'm not sure about your 97.
don't forget that you will need a built in tranny cooler, unless you have an aftermarket tranny cooler mounted somewhere.
I was going to buy an aftermarket cooler, but if I can just invest in a nice one that has the cooler on it, that would be awsome. Do you know where I can get one with the tranny cooler already built in??
ORIGINAL: fordguy17
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
