Sponsored by:
Sponsored by: DashLynx
Hardcore rattle!? help!
Old 07-11-2005, 01:33 AM
94gtinMi
94gtinMi's Avatar
Default Hardcore rattle!? help!
hey guys first post! I have a nasty rattle coming from what seems to be the back end whenever I hit a bump. front tires hit the bump no rattle back end hits it and *rattle rattle* I have a 94 gt convertible. I just did the rear pads, calipers and rotors and everything brakewise seemed solid....any ideas what this may be?
94gtinMi is offline
Old 07-11-2005, 02:10 AM
02StanGT
02StanGT's Avatar
Default RE: Hardcore rattle!? help!
Springs may be old and tired or shocks. Does it do it with the top up or down or both?
02StanGT is offline
Old 07-11-2005, 02:34 AM
94gtinMi
94gtinMi's Avatar
both top up and down. I just took it on the first trip since I had it and the rattle seems to be a little worse now. I also have funny tire wear on the driver side the inside of the tire has worn pretty good. One guy said perhaps a busted shock mount, but that was the same guy that let me pull away from midas and didn't put my lug nuts on all the way!
94gtinMi is offline
Old 07-11-2005, 04:22 AM
HAUS
HAUS's Avatar
maybe your exhaust is banging against something underneath the car. is it an aftermarket cat back. or if its stock maybe the hangers rusted off the muffler or tail pipes and thats whats hitting. just a suggestion to check out.
HAUS is offline
Old 07-11-2005, 04:35 AM
94gtinMi
94gtinMi's Avatar
yeah the exhaust is tight I did check all that out, so thats not the problem either......oi the trouble!
94gtinMi is offline
Old 07-11-2005, 05:23 AM
02StanGT
02StanGT's Avatar
Did you check your suspension?
02StanGT is offline
Old 07-11-2005, 01:18 PM
99saleen351r
99saleen351r's Avatar
rear sway bar bushings or shock bushings or worse scenario is control arm bushings.Theres not much else that it could be
99saleen351r is offline
Old 07-11-2005, 01:54 PM
UhadMEatGT
UhadMEatGT's Avatar
It could be the wheelchair of the guy you ran over??
UhadMEatGT is offline
Old 07-11-2005, 03:34 PM
babygurl2000
I ♥ Acer
babygurl2000's Avatar
lmao
babygurl2000 is offline
Old 07-11-2005, 04:10 PM
paulstang
paulstang's Avatar
check your rear sway bar i had the same problem with my 95 and found out my rear sway bar was broken 94-95 rear sway bars are really weak....... almost positive its that
paulstang is offline
Quick Reply: Hardcore rattle!? help!
