Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-17-2009, 12:19 AM   #1
mustangcat
Hair Ballz
mustangcat's Avatar
Vehicle: 2000 Mustang GT
Default Drum Brake Questions!!!
Hey guys.
Really need your help on this one. A very cute girl I know wants me to help her with her truck on Friday. I like this girl, so help me help her!
It's a 1990 Chevy 1500 pickup. Drum brakes.
She says when she went to pressed on the brakes the other day, nothing happened. The truck has been parked since.
1) Could it be her brake fluid is low? Do drum brake systems have a fluid reservoir under the hood like disc brakes?
2) If it's leaking, will there be signs outside of the drums, or will I have to remove the drums to find leaking?
3) Any other assumptions?
Thanks lads!
__________________
mustangcat is offline   Reply With Quote
Old 09-17-2009, 01:22 AM   #2
67mustang302
Vehicle: 67 Mustang Coupe
Drum brakes work mostly the same as disc brakes, they just use shoes, springs and drums instead of pads and discs and calipers. Could be leaking, if the fluid is low then where did it go? Leak. Might need bleeding, shoes could be glazed/worn etc etc.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
67mustang302 is offline   Reply With Quote
Old 09-17-2009, 01:55 AM   #3
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
Quote:
That is incorrect. While disc and drum brakes serve the same PURPOSE, they operate in completely different WAYS. The drum brake system uses shoes that are pushed outward into the drum. The disc brake system uses pads that are clamped onto the rotor.
On to the problem. When you say nothing happened- I'm assuming you mean that the brakes didn't work at all- thus, the pedal is to the floor. If that's the case, than it is most likely a leak. HOWEVER, if it could also be air in the lines, or a bypassing master cylinder.
Believe it or not, the basic brake system hasn't changed much at all, and still relies on the master cylinder pushing fluid to the calipers and/or wheel cylinders for movement. There will also be a brake booster located behind the master cylinder that adds braking assist (it's a vacuum operated setup with a hosing running from the intake).
GOOD LUCK WITH THE GIRL!
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 09-17-2009, 08:54 AM   #4
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Vehicle: 4000 - 0 -.5 Yes, thats right. I tied half a race.
Send a message via AIM to JD1969
That truck will only have drums on the rear. Go check all the same basic things like you would on any car. Check for leaks, fluid level, pad/shoe wear.
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
Quote:
Originally Posted by Sidewayz6.0 View Post
I'd **** OPRAH!!!!!!!!
JD1969 is offline   Reply With Quote
Old 09-17-2009, 09:00 AM   #5
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
BlueBloodedPony's Avatar
Vehicle: 00 Stang shooting a full clip
If there is a leak at the rear, check the wheel cylinder, top dead center of the drum. Typically, they are the first to go when there is a problem in the rear. Though, I doubt it is that because when brake fluid leaks into those shoes, it likes to grab and lock the wheel up while the brakes are depressed, not the opposite. A 1990 truck most likely will have brake line rust, check the cylinder reservoir to make sure she has fluid, if not, there is a leak and a line has blown out somewhere. Otherwise and hopefully, she just has worn brake shoes and they need to be replaced. The springs can be difficult, I like using a good set of pistol grip needle nose pliers to grab and pull them. When installing the springs, wear eye protection. Should the needles loose grip as you are pulling, they will hit your face, ask me how I know. Other than that, have fun and post pics of said female lol.
__________________
2000 Ford Mustang GT; Accufab 75mm TB&P; JLT cai; SLP lm2'S; Summit O/R H; Sniper tuned; 4:10's. SFC's, Tokico HP Series Shocks & Struts, H&R Super Sport Springs, MM Caster Camber Plates, UCA's & LCA's all are here; To be installed shortly
Quote:
Originally Posted by Rdot9 View Post
...mmmm nice and thick ftw...
BlueBloodedPony is offline   Reply With Quote
Old 09-18-2009, 02:39 PM   #6
mustangcat
Hair Ballz
mustangcat's Avatar
Thanks for the assistance guys!
Looked at the truck today. No leaks, plenty of fluid. She said the brake pedal felt "super stiff" almost too hard to push down. And it doe's it every once in a while, but not all the time.
I suggested that she bleed her brake fluid since both the front brake pads(disc like JD said) had plenty of pad left.
Any other ideas of what might be going on?
-MC
__________________
Old 09-18-2009, 02:43 PM   #7
1ATony
Sponsor
1ATony's Avatar
Vehicle: 92 Ford Mustang
Check to see if the caliper(s) may have froze.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Our Our Ford Mustang Parts
1ATony is offline   Reply With Quote
Old 09-18-2009, 02:44 PM   #8
mustangcat
Hair Ballz
mustangcat's Avatar
Is it possible that the calipers froze then unfroze?
Since it doesn't do it all the time, just some time.
__________________
Old 09-18-2009, 05:12 PM   #9
67mustang302
Check the power booster and lines, it may have an intermittent leak.
__________________
Old 09-18-2009, 05:12 PM   #10
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
Maybe the brake booster.
Edit: ^how the F man! but yes check for a leak.
__________________
brake, brakes, caliper, drum, grab, grabbing, hard, locking, mustang, push, suck, tight, unfroze, why, work
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
