cigarette lighter and driver side powered seat doesnt work!
I have a 94 v6 mustang, I put in my new fog lights they work perfect! But now my cigarette lighter and driver side powered seat doesnt work! Im pretty sure i blew a fuse. I checked all the fuses in the fuse box under the stering wheel area and they are all fine. Are there more fuses under the hood or does it have to do with something else?
RE: cigarette lighter and driver side powered seat doesnt work!
Go back and double and triple check your fuses, the cigarette lighter and the power seats are probably linked together through a fuse. How did you check them? Just visually? Get an electronic fuse tester, sometimes you can see that you have a blown fuse.
use a test light to test them.Turn the key forward and touch both sides of the fuses while its still plugged in if one side doesnt light up the fuse is bad.Its better to test them like that cause sometimes you cant tell by eye that thier bad.
waid302
09-14-2015 11:19 AM
