Emissions - Sorry I am new
Hi,
My check engine light just came on, and I had the code run, and it said it was my emissions. The guy at Auto Zone gave me a print out, and it said:
P1443
Definition EVAP canister purge valve mechanical fault or VMV fault condition
Explanation
ECM detected a fuel tank pressure change greater than 6 minus 7 inches of H2O in 30 seconds with a purge less than 0.02 lbs per minute.
Probable cause
1. Failed EVAP Pressure sensor
2. Blocked hose between purge valve and FTP sensor
3. EVAP purge valve stuck closed
Is there a cheap and easy way to check which one it is?
P1443
Explanation
Probable cause
mrappe
09-26-2015 10:16 AM
jpplaw
08-22-2015 09:29 PM
