Instrument Panel Lamps
Hi...Is it possible for a "weekend mechanic" to replace burned out bulbs in the instrument panel of an '02 Mustang? I have bulb burned out behind heat/air/defrost rotary switch,and my local dealers says it is a dash tear-apart, at the cost of approx. $130 for labor!
Thanks!
Mike
Thanks!
Mike
RE: Instrument Panel Lamps
Sure thing.
It's not a dash tear-apart thought. It's a little bit simpler, the entire dash don't come off. I don't know how to do this on stang though, I'm just replying because nobody else did.
If you are talking about your A/C controllers, then it should be simpler. Remove shifter bezel/console to gain access under the switches. You should reach bulbs from there.
dude cant you take the cover off and replace the bulb yourself?
umm my 2000 stang has 2 bolts up on the top of the cover to get to the cluster.
its pretty simple. I would do it yourself unless you got all kinds of money then pay me to do it. lol
bulbs are cheap at autozone
ORIGINAL: babygurl2000
Get a brushed or mirror finish stainless stell A/C panel cover (as shown) and put over it, then you won't have to deal with any of those bulbs.
Matt's 95 Stang
10-05-2015 07:16 AM
