Sponsored by:
Sponsored by: DashLynx
My Roush M90 is making horrible noise.
Old 05-02-2011, 08:47 AM
albertdale3529
albertdale3529's Avatar
Default My Roush M90 is making horrible noise.
I own a 2006 Mustang GT with the M90 Roush upgrade. I started hearing marbles grinding against each other within the Super Charger. I parked my Mustang. Can anyone help me? The Super Charger is so expensive, I do NOT want to buy a new one, I want to repair it. It sounds like the bearings are going, but I do not know. Is this a common problem with the Super Charger?
Thanks
Dale.
albertdale3529 is offline
Old 05-07-2011, 05:30 AM
wizwrath
wizwrath's Avatar
wow, you may have couple of issues you might want to think about, you mightve forgot to add/check/change oil in the blower case, either way, I would call Roush and ask them for recommendations for repair, but keep in mind, if the bearings went out and caused the rotors to hit the case, etc. then you are most likely better changing out the unit, the other thing is, if the rotors was rubbing the case etc. then the metal shavings had to go somewhere....stop driving it, take it apart or to a mechanic, look for metal into the intake ports, etc.
wizwrath is offline
Old 05-13-2011, 01:35 PM
LilRoush
LilRoush's Avatar
I'm gonna agree. Sounds like an oil issue in the snout.
LilRoush is offline
Old 05-13-2011, 04:08 PM
67mustang302
67mustang302's Avatar
Yup. Even if it was oiled the bearings can still fail for a variety of other reasons, particle contamination in the oil, too much belt tension etc. Definitely do not drive it though, and get it checked out.
67mustang302 is offline
Granatelli Sales
01-20-2020 12:34 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
TimeLord101
09-04-2015 09:27 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: My Roush M90 is making horrible noise.
