I have plans for a pair of Flowtech Purple Hornies coming off of a pair of Hooker Super-Comp headers on a 302. Purple Hornies are the glasspack exhaust you usually see on Jeeps. They are 2 feet long that bolt directly to the headers. Does any body know what I'm talking about? Are these good choices?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
yeah i know what your talking about, they sound like a typical glasspack. lots of ppl from round here put them on there trucks, sure there are really loud and snappy but i dont think theyd suit a stang very good, go with a race bullet if you want that style and it will give a pretty good sound too. but the header pipe type of thing is pretty sweet tho.
I have a 68' Coupe 200ci 6 banger (As if the other two stangs werent enough!) that has single 2.5" exhaust and a 20" cherry bomb and EVERYONE always asks me if I have a 289 in that car and I tell them that its only a 6 banger and they ALWAYS have to check my engine to make sure. It sounds great and if the PH's sound as good then get them, just watch for cops!
Summit has an adjustable resonator that you can put inside your collector that will lower the sound a little, good luck!
~April~
__________________
Dont just sit there, watch for cops!!!
Actually no muffler outflows even the cheapest glasspack. A thing called race mufflers, for example edelbrock race mufflers, or SLP race mufflers, they are no mufflers they're high quality glasspacks.
The longer the glasspack the queter it will be. A rule of thumb is to get 1 foot for engine with cats, and 2 feet for engine without cats. Sh!t, glasspacks are enoying, I had them.
No those are straight through mufflers, and even though they might use fiberglass or a similar material to help deaden noise, they do not even similar sound to "Glass Packs" if you ever look into an old school glass pack you will see why, they have little ridges that disrupt the airflow, a muffler such as a Dynomax Bullet and the ones you mentioned will not have any ridges. If glass packs flow so well you would see them on all the fast cars in classes that require mufflers, but nobody has them.
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
ORIGINAL: JD1969
They do, they call them race mufflers. A race muffler is a straight through pipe that deadens sound. A glasspack is too a straight through pipe that deadens sound. You can call a glasspack a straight through muffler if you like, it don't even have to be packed with glass fibers. A muffler has chambers that cancel sounds and restrict flow, a glasspack (or straight through muffler, or race muffler) does not have chambers and sounds are not canceled out, the sounds are deadened. That's the difference.
Different straight throughs will have different properties that will deaden some sounds more than others, and thus they'll have different level of annoyance. Sounds considered annoying are generally above 3kHZ.
Ok now you are just trying argue semantics, a muffler is any device that muffles (hence the name muffler) sound. I have read alot of your posts and quite franky, 90% of the time you don't have a clue what you are talking about
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
