Sponsored by:
Sponsored by: DashLynx
Air conditioner stopped blowing cold air
Old 01-16-2014, 12:58 PM
Murphdog
Murphdog's Avatar
Default Air conditioner stopped blowing cold air
A couple days ago my a/c stopped blowing cold air. I've seen posts about buying some kind of can at the local autozone, and also posts about getting a tech to take a look at a possible condensor problem. I'm of course out of warranty now. Has anyone else delt with this on the S197 or have a recommendation?
Murphdog is offline
Old 01-16-2014, 01:05 PM
Derf00
Gentleman's Relish
Derf00's Avatar
If you need to add Freon to a system, it has a leak. Adding Freon to a leaking system is a Band-Aid fix that won't last long.
Best thing to do is just take it to a shop and have them do a $60 diagnostic on it. If you are mechanically inclined then after they tell you what is wrong, you can fix it yourself or have the shop fix it for you.
The alternative is to buy a set of A/C Manifold gauges ($100+) and learn how to use them. You'll still need a vacuum pump though (another $100+) to recharge your system properly after you open it up to fix whatever is wrong with it.
Derf00 is offline
Old 01-16-2014, 02:27 PM
Fryguy22
Fryguy22's Avatar
recharge it with Freon and see if that fixes the issue. If it doesn't, then go get it checked out.
Fryguy22 is offline
Old 01-17-2014, 08:26 AM
Murphdog
Murphdog's Avatar
It seemed to work better yesterday, not at 100% but maybe 85%. I'll keep an eye on it. thanks for the advice.
Murphdog is offline
kevsgt
09-09-2015 06:20 AM
09-08-2015 11:50 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Air conditioner stopped blowing cold air
