turn signal problem
turn signal problem
Hey there,
I just realized last night, that my turn signal (on drivers' side- in the front and on the back) are not turning off anymore. I took the key out of the ignition and locked the car, but still the turn lights burn. (They burn constantly!)
I checked all the wires and fuses, but I think it might be the relay.
Does anybody know where to find the turn lights' relay?
Or maybe someone has experienced that problem before and is able to help me? I am really running out of ideas.
Thanks so much!
Thanks so much!
Does the left side blink, if so it's not the flasher relay. I'm on the smartphone app so I don't know what year car you have, but they stay on with the key off, sounds like the Hazards. Never mind, they'd all stay on. Sorry can't help more.
@AZpete:
It is the turn light signal. Well, as it was raining a few days ago there might have been some wetness on the passengers' floor. But I couldn't discover any wetness in there now. So that should be ok.
Sadly I couldn't find a fuse for the turn signal. Is it a fuse with another name tag on?
Thanks a lot for your advice to both of you!
Try swapping the bulbs from side to side.....see if the problem follows the swap.
If a turn signal flashes faster on one side, that is very indicative of a bad bulb on that side.
I would pull each fuse and relay one at a time to see if any fused circuit is causing the issue.
I think I heard of someone with this issue having it be a bad multi function switch but have been unable to find the reference. Could disconnect it and see what happens.
